I'm moving a couple of downstairs rads and also possibly changing some valves for TRVs on an open vented system. There are is no drain point that I can find and the pipework is below a wooden floor.
I'm wondering if I close the gatevalve on the CW out from the F&E tank and also cap the vent, will there be enough vacuum to allow me to work on the pipes/valves? Also probably closing off all the rads to isolate the water in them? I want to avoid a full draindown if at all possible since it looks like it's going to be a pain (there's no route to the outside below the floor to drain anything and I guess it's a bad idea to drain onto the earth subfloor).
I'm planning to get the new pipework ready with a pushfit to join new to old so it would be a matter of cutting through the old pipe and attaching new pipe with that pretty quickly.
