How does one open up an Acer Advent to effect a repair ?
This laptop appears to have a loose connection between centre pin of the 20 volt power socket and the PCB. ( measuring resistance between the pin and chassis shows open ciruit until slight pressure is applied to the pin when 3K5 is measured )
So I need to open the case and inspect and make the mecessary repair.
Problem after removing all fixing screws the case will still not allow me to open it to expose the PCB.
Also need to locate a source of the Acer ( or 100% compatible ) spring contact power plug.
History is that the wrong size power plug was tried and this seems to be the cause of the damage.
