The wall in the photo is a single skin supporting "spine" wall which houses the staircase in my victorian semi.
I am planning to house the wooden box which is 460mm wide and 200mm high into the wall which will house my sky box and wall mount the TV above I plan to put a concrete lintel above for support but wasn't sure whether I would require the full 150mm clearance either side. Can I knock out the bricks and insert the lintel without temporary support??
My concern is that the masonry won't be very tight as it is contains the original lime mortar.
All the electrics would be housed in the understairs cupboard.
Many Thanks
Many Thanks
