hi,
I'm considering paying a firm to sound proof my living room party wall in my flat. (I'm midland based)
The wall is 14ft by 8ft. Flooring is concrete. No one is above me - there's a loft.
The noise is mainly airborne, talking and shouting etc. Residual noise I can live with.
Opinions welcomed in the below quote....(they haven't seen premises yet)
Quote.
To prepare the wall we will cover any items of furniture and carpets with dust sheets and carpetprotector.We will then remove any skirting board and electrics.
We will also remove the radiator.We will lift up a few of the floorboards close to the party wall and insulate against the partywall to reduce flanking, We will then refit the floorboards.
We will then start constructing a fully independent acoustic wall which will be made up using a3'' timber frame which we will then fill with RW3 75mm Acoustic Quilt.Once the frame has been filled we will then add a layer of 15mm 49KG soundbloc board sealingall the edges and joints with acoustic sealant.we will then add a 16mm Sound breaking RB1 bar which will provide a secondary air gap.
We will then add another layer of 15mm Soundbloc board again sealing all the edges and jointswith acoustic sealant to maximiser performance.
We will then plaster ready for decoration and then refit the electrics and skirting.The radiator will be refitted and bled to ensure the radiator is in full working condition.Throughout the process we will ensure that the rooms remain tidy to minimise dust All rubbishwill be taken away.
£1400 +VAT
Quote.
£1400 +VAT
