Hi folks,
just had new boiler fitted (for info- glowworm regular condensing fitted on existing 20yr old old standard open vented system, 22mm system pipes but microbore to rads (4 upstairs rads, 4 down plus HW cylinder).
So he didn't wire in a pump overun (the wiring wasn't there was his excuse) so am fitting this wiring myself. (I know what I'm doing with that fine...)
But also didn't flush the system & it's a bit mingin really. For the price the job is ok but obviously not installed to manuf spec so needs cleaned. (Yes i won't go with the cheapest quote next time ('')
So.. now looking for some opinion on cleaning the system.
So questions for your opinions:
1. I take it if the water isn't clear (black/brown) then it could knacker the new boiler and invalidate warranty so really does need cleaned right?? HOW bad is it for a new boiler, like should we be cleaning it asap or ok to run for a few weeks first?
2. If yes, then can I shove some cleaner in it & run on fairly hot for say a week without risk of damaging new boiler with cleaning chemical?
3. Is this a waste of time anyway cos unless I flush it properly I won't clean it out properly??
Few years ago I took the downstairs rads off & flushed in garden with hose, put in cleaner for a week then refilled with inhibitor so thought it wouldnt be too bad, but now when drained & refilled (twice) during install it's dirty looking water. Having done this I don't fancy the removing rads option again....
I've read the faq on using mains water from a hose to flush (here: //www.diynot.com/forums/viewtopic.php?t=38902) which is great but the hassle of having to temporarily replumb the expansion tank/vent etc is putting me off.
If folks think that's a good options then my next question is
4. Is disconnecting the flow and return from the boiler and using those pipes to connect hose fittings and run the water through to flush (in both directions) a good place, does it matter?
5. Will it damage my pump (which is under the floor although I have access to it) to run mains through it? If i remove the pump & run the flush through the rest of system then I'm flushing through new boiler instead which is worse right??
7. Any other opinions on best way to cleanse (powerflush machine is ~£80 would save replumbing tank, good option?)
Sorry I know this is long debated but given the system info hopefully someone has some advice on some of my questions..!
Thanks folks...
PS forgot- last ask- how much give is there in 22mm compression fittings when pipes are at a bit of an angle entering say a 22mm elbow and ptfe tape is used.. will they last as long as not leaking (angle into one of compression fittings is like maybe 15 degrees or something where feed is connected above boiler... cheers...)
Thanks folks...
