Opinions on these wet ufh components
15 Nov 2010
looking at purchasing a kit on line and have been quoted for the following, what are opinions on the equipment provided? Is there anything specific I should confirm with them?
• Multilayer pipe 16 x 2 mm – PE-rt/AL/PE-rt approved for 10 bar pressure and 95 degree C temperature
• High quality Manifold(s) with flow regulators, on/off valves, filling valves and ball valves
• Control Pack(s) for mixing the water temperature to the underfloor heating system with 6 m
Grundfos pump and a Highflow RWC mixing valve
• Danfoss TP5000Si programmable digital individual room thermostats with set-back
• Danfoss electrical Actuators
• Danfoss wiring centre(s)
• Clips for fitting the pipe to the insulation
• Pipe fittings for connecting to the manifolds
• Calibration tool and a Pipe cutter
Thanks in advance.
