I was drillin up into the loft to run a cable up for the ariel and checked and double checked where i was going through but when i had finished i went in the loft and had managed to drill through a beam one of the thin ones . Its only about 1/6 the width of the beam and the drill hole only small. it was in a cupboard so the beams sitting on two walls about 30cm each side of where i did it.
Also on most beams we have screwed in pasterboard in underneath and in the loft we have boarded it out. The screws used for tht are about the same as the hole i made. I know its not the same thing.
What u think, dosent look big enough to be a prob and as the beams have the screws the same width top and bottom they must sooort of be the same thing. Dont plan on doing it again.
what you think?
what you think?
