- Joined
- 9 Dec 2007
- Messages
- 14
- Reaction score
- 1
- Country
Hi guys,
I have recently have had some building work done and the mains electric had been off for a while.
So the batt. went dead in the control panel. I replaced it with a suitable one and it was fine, system worked ok, although the reason I suspected that the batt was dead is that the keypad had locked up and the power light was out on the keypad.
Anyway the system was now up and running. I needed to change 2 of the PIR's as they were damaged from the building work I had done. While changing these 2 PIR's, I cut the wires from one of them and the alarm started sounding, i.e. the tamper light came on, I entered my code and it stopped.
But the situation is now is that the tamper light will not go out and the keypad is not responding to anything. The power light is on but the day light is off. The strobe on the housing outside keeps going off aswell!
I have tried to unplug the main and the batt. But still no joy the tamper light is still there when I reconnect and just the power light and no day light.
When I do reconnect though the keypad starts beeping and have to enter my code to stop it. It then reverts back to the tamper light etc.
I have removed the fuse from the srobe/PIR's at the mo, just to stop it keep going off outside.
One other thing when I cut the wires to one of the PIR's to shorten it and the alarm started sounding, the fuse for the PIR's also blew in the control panel (1.6amp), which I replaced and is still not working correctly.
So basically I have:
1) Keypad which only the power light on and no day light
2) Keypad locked out, as when I push any buttons it does not respond
3) Keypad, which has the tamper light up and will not go out when I press reset as the pad is locked up
4) Strobe going off all the time in the box outside my house (when the fuse is put in)
Your help would be so much appreciated.
Many thanks
Many thanks
