Hi, I've wired one of these, dead simple (should have been) just two PIRs and an internal speaker. Couple of problems:
1) When putting the battery jumper to "ON" on the bell box, the siren sounds, but remains on even with cover back on. Stays on even if hold tamper switch closed manually.
2) On the control panel, seems locked out, even if reset with eng. code.
Have tried the manuals instructions to reset to factory default, makes no odds. have tried just linking the tamper terminals out, still the same. So I figure it can only be a tamper signal (o/c) from the cover of the panel or the bell box, both, I'm pretty sure are operating.
3) The internal siren box, should this just tap on to the panel speaker connection terminals, in parallel ? It seems to work that way but no instructions otherwise.
Any ideas ?
Any ideas ?
