I have an intruder alarm system with an 8EP 396 Optima G3 compact panel which has been working perfectly for years. Recently I have been getting occasional false alarms, always on zone 2. It appears that these false alarms are triggered by someone switching a light on/off or by the central heating system switching on/off.
I have replaced the battery but no change.
If I link out zone 2, there is no problem.
Walk testing the system shows every sensor working OK but when activating a sensor on zone 2, instead of getting 2 bleeps continuously, every so often one or two pairs of bleeps are missing (e.g. bleep bleep, bleep bleep, bleep bleep, - -, bleep bleep etc), whereas the bleeps on zones 1, 3 & 4 don't miss.
Zone 2 has 5 magnetic door sensors (normally closed) and one pressure pad (normally open, connected across to the 0v terminal).
What do the missing bleeps indicate and how can the system be affected by switching external units on or off? What do you think is causing the false alarms?
Your comments and suggestions would be most welcome.
