My Optima XM has given excellent service, so good that the finger key pad on the door is worn out. Having recently decorated I would like to change the key pad cover,or if necessary the door or as a last resort fit a new alarm with the same footprint. Any ideas?
EDIT: Honeywell (ADE) now only make the compact case, which is smaller and slimmer than yours. They also make a larger metal case, which may well cover your old panel's footprint, but whether you have the space or not, I don't know.
