In a few weeks, we're ripping out our one pipe 1960's system and installing a totally new setup. Current broad specification is a system boiler, 210 U/V Cylinder and 10 rads. We're in a 4 bed detached with two bathrooms.
Given it's a blank canvas and we use our home very differently through the day and day to day, I'd like to fit Evohome so I can zone the rooms and only heat what we need, when we need it.
Our plumber is happy to fit what we want, leaving the binding of TRV's and set up / scheduling to me. He's currently suggesting a circa 30kw Baxi or WB boiler. Though, he's not used evohome before so he's relying on me to make sure everything evohome needs is covered.
One question I have is concerning opentherm, is it worth it? Using this to allow the boiler to modulate the flow temp to maximise efficiency? From the looks of things, it's not well supported from the boiler side and what would we lose or gain from alternatives?
Apart from that, is it as simple as just installing everything then setting evohome up or do we need to consider other elements / components when building the system? I just want to be certain we're considering everything we need to and don't end up with something that works poorly.
