Options for loft insulation AND storage please
Hello there, I am in the process of insulating the loft in my Victorian house. But I also need to use the loft for storage. I'm interested in people's opinions on how to achieve this please.
Here's what I know:
- I am going to use 270mm of mineral wool or rockwool insulation, as it is cheap and easy
- I know that you mustn't compress the insulation once laid, as squashing it stops it working as well (obvious really!)
- So I am not going to put boxes directly on top of the insulation, nor am I going to screw boards down at joist height. But I need to find a way to store these boxes in the loft. They are not heavy, but there are lots of them and I don't have the space elsewhere.
I've looked online and my options seem to be:
- to raise the joists with timber to above 270mm and cross-batten, but I'm worried this will add quite a bit of extra weight in the loft and I don't have easy access to get all the timber in? What do people think about this extra weight?
- not use mineral wool or rockwool but instead use PIR boards (eg Celotex, Kingspan). But this works out much more expensive to get the same insulation value. I've also heard of condensation issues when you put boards directly above solid insulation? Have people come across this problem?
- use some new products I've seen, like Loft Stilts (http://loftstoragestilts.com) and StoreFloor (http://www.loftzone.co.uk) , which both provide a raised platform above the insulation. Has anyone tried these? What do you think of them?
Any advice gratefully received, thanks!
Here's what I know:
