Orange in boiler flame
21 Jan 2010
Manchester
I've noticed quite a bit of orange in the flame of my 240 RSF:
http://galatea.salford.ac.uk/aix502/07032010011.mp4
Download the great free video player, VLC, if you can't play that:
http://www.videolan.org/vlc/
The CH and DHW are good and hot.
I have a working carbon monoxide detector just above the boiler. Which tests ok and has never triggered.
I was wondering if that amount or orange is an indicator of some fault?
Would that be dirty jets?
I did have a GSR guy perform a service in Jan. He said he'd tweaked the flame and it was now burning better than before.
I was having a DHW over temp tripout issue at the time (since fixed) and he said that it might need a new gas valve to fix that, but not to improve the flame, which he reckoned was fine when he left.
Thanks.
it doesn't look too bad. ideally it wants to be a sharp blue flame, maybe a little orange sometimes. when it's floppy yellow is when you need to worry. a performance test should tell you, the guy who serviced it should have done one. You want a ratio of less than 0.0040
Give the side of the boiler light thump with your hand...then you'll see orange flames...it's just rust particles. Yellow tipped flames are however a problem. Despite its age your burner is in fact likely to be far safer than a modern Band A boiler.
Thanks guys.
So orange ain't bad, just yellow.
Does the orange indicate any failing? Poor efficiency? Or simply a bit of dirt?
