Orbry or Hydro tilebackers
30 Aug 2010
London
Orbry and Hydro are two tile backers which are available at 2500mm lengths. Can you please let me know if you have experience with either of them or maybe or both? Which do you think is best? Thanks
to be honest cement tile backer is cement tile backer.
Gotya. Thanks. The Hydro boards are insulated cement coated boards unlike the Knauf boards which is a solid cement. I'm using 10X30mm ceramic tiles. Do you think a 12.5 thick hydro board enough?
I will need to dot and dab 5 or 6 boards to my brick wall and then ensure that they are all flush and square. Is Mapei Keraquick 20Kg Fast Setting Flexible Adhesive a good choice or will it cure too quickly? if so what is a good alternative?
