My builder is currently doing a shell for me, which I will be fitting out.
I will be putting down floor which will have UFH pipes within 65mm screed, drylining the walls and plasterboarding the ceiling.
Does it matter what order these jobs are done in? I presume the floor would come first? Does it then matter about the ceiling and walls?
Secondly, the dry-lining; one of my walls will be a stud partition wall, so this one will need mechanical fixing. Add the ceilings, which will also be screwed up, is it worth screwing the other walls too (to battens), then getting a skim? At one stage I was thinking of dot and dab, but the mix up looks pretty messy.
If I am getting a skim anyway, many of the benefits of dot and dab seem to be lost.
