OSB internal walls paint
17 Jan 2023
Hi all, I have internal osb walls, advised Bedec barn paint or Bedev multi surface, which would be best?
thx
Some external paints have nasty chemicals that prevent moss and algae growing so can be unhealthy if used inside. Read the data sheet online for both paints and see if they can be used inside ok. If yes go with the one you like the most after reading the data sheets
