We have a Oso 20 RI cylinder which is supplied by a Vaillant Turbo Max boiler. The system (CH and HW) has been fine for 8 years with annual maintenance. Just recently we noticed that the HW "fades" after a couple of minutes at every tap in the house. The water then runs stone cold. If the taps are turned off for a while and then turned on, the cycle is repeated. The CH is fine. The boiler fires up. The inlet pipe from boiler to cylinder is hot and the outlet pipe from the top of the boiler is also hot so we know the cylinder is full of hot water. Any ideas what could be wrong? Our regular service engineer thinks there may be an unnecessary (and indeed hidden) blending valve somewhere but is otherwise mystified. All ideas/solutions welcomed please.
