Please Please Please can someone help me.
Been living in a new build house for past 4 years and having problems with my hot water supply/ central heating since the day we moved in.
The 5 bed house runs off a Oso condensing cylinder. Approx every 4-5 months there is a surge in pressure to the hot water taps followed by a few radiators springing leaks. I've been told time and time again that they run independant of each other and not to confuse the two. So why do they always go hand in hand?
I am not technically minded but have built up a good awareness of this system over the past 4 years. I understand the reason for the surge in hot water pressure is due to the air-pocket in the cylinder being replaced by water. This is also confirmed by the fact that water ommits from the tundish when the surge in water starts up, and remains until the plumber has re-charged the air-bubble again.
Attempts to remedy the problems have been:-
replace separate pressure gauge
replace separate expansion vessel
upgrade water meter from 15mm to 22mm
check stop-cock opened fully
replace showers as possibly faulty valves allowing water back into the system
all olives and joints to radiators replaced incase poorly made-up or overtightened!?!
can't remember the figures but supposedly there is also good water pressure/ supply to the property
The guy from Oso himself has even been to visit me and suggests the problem lies with the mains pipework. The majority to the property is 32mm but where it is connected to the water meter, a small part of it reduces to 15mm. Great - just get the water company to increase the size of the pipework? Not so - this is standard on all the meters, and unfortunately I seem to be the only one on this 70 house development with problems to the hot water supply. Having said that, I know numerous neighbours who have leaking radiators but some are just living with it by putting bowls underneath to catch the drips!
Is there anyone out there who can throw any more light on the situation or advise an alternative 'good' and 'easily maintainable' unvented cylinder?
I will be your best friend for life if you can help!
