Hi, I have a question to the experts on this forum. I have an out-building which has been built of concrete blocks externally and celcon/ breeze blocks internaly. What I would like to know is, it best to render the internal blocks as the external blocks are only pointed or should the internal walls be plastered with browning. If rendering is the best option than should a scratch coat be applied before the top coat, and then be finished with multi finish. Also how do i avoid cracking in the plaster work in such a large area. I did consider the dot and dab method of plaster boarding but want the best method. Advice greatly appreciated and many thanks in advance.
