Out of date adhesive.
25 Jan 2010
Coventry
Out of date flexible tile adhesive.
Can it be used? Or will there be consequences?
Many thanks in advance.
Lou.
I've no idea but how would you feel if it caused you problems and you had to remove your tiles and start again?
Is it worth the risk?
Well i certainly would NOT want any problems Garymo. So if there is a chance of problems by using out of date stuff, i will not be using it!
I was just wondering as most things these days have a use by date , where really its just for manufacturers to cover themselves and the stuffs probably fine.
Ive had flexi that I found at the back of my garage and used,been there for months .Worked ok only thing being that if its rapid set it will go off a bit qucker. ;)
