Good day fellas,
I have this TV in the bedroom. http://www.argos.co.uk/static/Product/partNumber/5295559/Trail/searchtext>BUSH+LCD.htm
Until recently have been watching TV thru sky dish without any problems. box has died so got new ariel wire fed through to bedroom to use the built in freeview.
Cable used for the ariel was the existing sky cable hooked up to tv antenna and connector changed in the bedroom.
Antenna on house is approx 2 years old, engineer said signal was brill, so he only had to fit a splitter not a booster.
Seems that on some channels, mainly the ITV ones, the sound and picture are out of sync, if I do a retune it syncs up, but once TV is turned off & on again its out of sync again.
TV downstairs using the same antenna has no problems at all.
Any suggestions.
Cheers
Rico
Any suggestions.
Cheers
Rico
