I am currently musing over converting my outbuilding into a kitchen.
The current outbuilding is about 10m long and about 2 meters wide.
The outbuilding is combined into 3 rooms ending in an outdoor privvy.
I want to knock through he first 2 walls and leave the privvy to its own devices. The walls do not support the roof (which if aspestos cement sheet - but i would felt this and keep the roof as is) and contain no supporting electrics.
Basically my question is this. I want to create interior partition again the exisitng outer walls and a false level roof (the roof is slanted at 45deg) using 2x4 and plasterboard. A lot of folks have recommend using jabalite or insulation slabs as insulation but i recently converted my garage into a soundprrofed studio using 2x4, platerboard and 170mm rockwool insulation. Because the walls may be slightly uneven I feel the job would be better servered by rockwool for insulation.
What do you think?
I also understand that planning regs may be required to knock down interior walls. Can anyone give any guidance on that issue?
Any help would be great thx.
What do you think?
