Hi all
Currently have just one 10 watt LED floodlight mounted on side wall which is switched by a standalone PIR mounted about 3.5-4 mtrs towards the house front.
Cable is 1.0mm from 6amp lighting circuit breaker then through a 5amp switched fused spur,out through wall approx 2mtr to a ip65 junction box,4 core 1.0mm to PIR 4mts max,then tail from light into said box 0.5mtr.
Looking to run another 1.0mm cable from the junction box to the rear of the house around 6mts max,to run another 10 watt PIR LED.
Would this be ok ?.Thanks in advance.
