Morning Guys,
A quick question for you. I have a 150W Floodlight fed from it's own 6amp breaker about 2meters away. I wish to add another outside light 60watts and PIR approx 8meters away. The cable will be clipped to an outside wall. I was going to use 1mm heavy duty 3core black flex to wire the new light and PIR. Is this acceptable? - if not what type of cable should be used. I have thought about high-tuff but there won't be enough room to feed this and another cable into the PIR.
Cheers,
Richard
Cheers,
Richard
