Outdoor lights and wall socket
15 Nov 2008
Staffordshire
Could someone advise the most suitable way to add a new spur into a consumer unit in my garage that will power 2 outdoor sensor lights and a wall socket. Was thinking of running the spur to a switched/fused point then to switch for outdoor lights and opposite direction to the wall socket.
Thanks for any help :D
use the switched fused point as the switch.. saves on a switch..
[code:1]
16A breaker - 2.5 cable - SFCU - socket
outdoor lights[/code:1]
oh and Part P..
since this is both an outside lighting install, a new circuit and possibly a new breaker it will be notifiable to your LABC prior to commencing work..
you're also limited to the amount of floodlighting you are allowed on a domestic property.. 150W.. not sure if that's each or total..
