I have one of these http://www.screwfix.com/p/bg-nexus-13a-2g-dp-switched-socket/67928 and was going to use 2.5 T&E cable. The cable will be coming out through a wall and I intend to use the bottom entry point. My question(s) are: Is it better to use T&E or normal round 13A cable? Should I use a plastic cable gland or would one of these do? http://www.ebay.co.uk/itm/301227948423?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT which I already have. The cable will be coming out of the wall and going straight into the socket.
P.S. The instruction say that if using the top or sides knockouts to drill a drain hole in the bottom but if using the bottom entry NOT to drill a drain hole. This doesn't make sense to me. I would have thought a drain hole was essential.
Brian
Brian
