I am looking to install an outdoor Masterseal (IP66) socket and outdoor light. I'm going to get a spark to connect them up to be on the safe side but want to do the prep by drilling and installing the cable, etc.
I have a few (basic) questions which I'd be grateful if anyone has any views on:
1. Is there a recommended standard height from ground level for installing the external plug socket?
2. I may also need to install an outside tap in the same wall as the external socket, are there any rules about proximity and location in relation to each other?
3. The cable into the back of the outdoor socket (and light) will not be exposed to direct sunlight but will be exposed to a range of temperatures. What would be the best cable to use - arctic, FP200, H05RN, etc?
4. The drill hole through the cavity will depend upon the outside diameter of the cable used but is there a rule of thumb for the size of the hole in relation to the cable diameter (e.g. 50% bigger, etc). I'm guessing there is no risk of heat build in this situation so the hole should just be sized as necessary?
Sorry if these questions are a little naive but is be very grateful of any views which are much appreciated as ever.
Many thanks,
Damian
Many thanks,
Damian
