Outdoor Socket
6 Nov 2004
Please Help:
I'm trying to fit an outdoor socket. The socket i've acquired is fully weatherproof with an IP rating of 66, unfortunately it doesn't have a built in RCD switch.
A friend of mine (well I hope he is?) he told me the easiest way to fit the socket is to use 3 core 1.5mm cable and also connect it to a standard RCD plug on the other end and just plug it in your indoor socket
can this be done, safely
I don't really fancy removing any sockets, I'm not really confident in using 2.5mm twin & earth cable
any help appreciated..
thankyou
i dont see a problem with that, aslong as the RCD is attached to the plug and not an adapter where the plug is plugged into (b/c the RCD could be taken away and socket still used)
Although T & E is not designed for attaching to 13A plugtops...
Try Artic blue, 1,5.
i kno it aint good practice, but thats how i powered 2 sockets on my desk for a few years... 1.5mm T+E into a 13A plug... i recently added a FCU next to the socket when i found a spare 1
Arctic flex into an RCD plug is fine. I`ve used one like that for a couple of years. If you look at many of the outdoor socket kits in the sheds (or even Screwfix) that`s how they`re wired. :D
Of course, folks, that should be ARCTIC.....
Jokes now invited re articulated cable....!!
:LOL:
Why didn't you use flex?
You can buy them - you don't have to wait until you find one lying about....
didnt have any lyin round
