Just want to clarify that what i'm doing is correct. I have a 10mm SWA cable running from the house to the garage. In the garage I have an RCD main switch, and I will install an earth rod. Just a few sockets and lights in the garage at the moment. However I now need to run cables for a garden light and I need a socket at the bottom of the garden. Should I run two separate cables or will one do for the both? thinking of running 4mm SWA. Run is approximately 60m. Any advice?
