I am rebuilding a raised outdoor terrace. The flooring will be stone tiles set on 18mm plywood. I know that I need a waterproof membrane between stone tiles and plywood but need help with what to use:
- is asphalt felt (primarily used for roofing) a suitable material for this? If so please could somebody recommend the type/quality/spec I need for this type of job because everything I have seen is only supposed to last for 15 years which is not good enough - I don't want to have to replace it that soon if at all.
- Is there another material (apart from asphalt felt) that would be better/more suitable and durable?
I'd appreciate any advice/help
