The backplate has come away from the through wall copper pipe from my outdoor tap. I have about an inch of copper pipe to work with on the outside with no access to the inside.
I've tried unsuccessfully to solder it back on as there's not much access to the joint, does anyone know if you can buy 1/2" hose union back plates with a solder ring in them?
