I've changed some plumbing in my kitchen and need to re-do my outdoor tap.
Previous owner had installed it with one of those nasty self cutting strap on boss things which was leaking, which led to a flexible hose to the tap, so i cut that out and replaced it with a proper T piece and a quarter turn isolator.
I'm going to put a double check valve on the inside after the isolator, then need to head out thru the wall.
I'm a little wary of using copper pipe, as though it looks the neatest option, i'm worried about it freezing. I was thinking of using plastic pipe going out thru the wall to the tap, but i think plastic pipe with its bulky push fit fittings might end up looking pretty gash externally, as i'll need to come out the wall then make a 90 degree turn down to the tap.
Any thoughts?
Any thoughts?
