Can you plumb the 22mm overflow from the cistern back down into wc outlet?
I have, or rather will have, a 38mm pipe running from the adjacent basin into the wc outlet and plan to tap into this rather than coring a hole through the porcelain tile and the wall behind.
I know there is a possibility of smells but in reality, how likely? The S&V pipe is just the other side of the wall and has it's vent to the sky, just a couple of metres above this.
