Outlet required fot existing aluminium Gutter
3 Mar 2005
Surrey
My mum's house has a pressed aluminium gutter - I think it was made to measure on site years ago and has lasted well. Originally, only one outlet and down pipe was installed at the front corner of the houe (3 bed semi) and now we need to install another down pipe at the rear.
How can I install an outlet in the existing gutter ? The flat part is only 70mm wide so I need something than can fit in a 50mm hole, leaving space for a seal. All the spigots on Ebay seem to be in America ?
Have a look at Koi carp sites . Lots of connectors used in the tanks/plumbing/pumps
All that is available is a Hunter R400. It fits inside a 68mm round pipe so I think it's finished OD is 66mm. We have loads at work I can check.
If you want 50mm you'll have to make something yourself. 50 is small though, only takes one leaf to easily block it.
