hi guys
i am in the middle of some home renovations and one of these means i need to move my immersion heater.
got it all moved ok,problem is its moved from one cupboard to another so i need to move the wall outlet that supplies it,upon inspection of the outlet its in a metal box with metal conduit ,the outlet is wired red to live black to neutral and the earth is wired to an earth terminal in the metal box,so i am assuming the actual metal conduit throught the hose is earthed?
i was wanting to move the outlet using a 30amp junction box and 2.5mm twin and earth cable,but when i come to conect the cable in the junction box the new cable(new brown and blue) has an earth in it but as i am no longer going to use the metal conduit i have no earth from the original wire to conect it to,so my plan was to use the earth connection of a nearby wall plug and run some earthwire from there to my new junction box.
does my method sound ok,any replies would be good
