I ought to state up-front that I'm being fussy...
I want to run about 3 metres of Cat5e cable (for a network connection) horizontally along an outside wall. I would like the cable to be protected from damage so looked for reinforced Cat5e cable but couldn't find any. Does it exist?
Alternatively, I could use rigid or flexible conduit. Problem is, I don't want it to look too unsightly yet the run is interrupted by a small external chimney breast which means the cable run will pass through two internal and two external corners during it's run.
In my opinion, using four typical inspection elbows with rigid PVC conduit to get around the obstruction will look odd/bulky. I've also seen outside flexible conduit installations and they look really naff because they sag badly even when supported every few inches. Is it possible to use a combination of rigid conduit with the flexible type used to get around corners? Can I connect rigid and flexible conduit together?
Any suggestions much appreciated...
