Outside casing of oil central heating boiler is very hot
6 Jan 2013
Radiators seemed very hot so I checked boiler settings. The setting was about 67 degrees however the boiler casing was very hot. Is this normal and I just haven't noticed it before. The boiler Is in a garage and is not enclosed in a silver outer "box"
Thanks for your prompt reply. I'm new to this site so it's taking me time to work out how to reply
Boiler is GERKROS
Model. GEM FDC 60/95
It is the front panel with boiler Details which is hot. Sides and top are ok
It could be that the boiler control thermostat is starting to fail (getting hotter than normal) however your boiler is fited with an Overheat Thermostat which will trip the boiler out before the water boils, in this event the overheat reset button would need to be pressed to get the boiler working again, if this happens you will know that something is definately wrong! in the mean time I would keep monitoring the situation ;)
