Hi There,
Apologies if this is not the correct forum, but would be grateful for any advice. My driveway slopes down towards the house from the road to the garage which has a drainhole to the front of the door. The drain flows under the house to the rear garden to a soakaway.
Following heavy rain the drain cannot cope and ends up flooding the garage. The water will then usually drain away in approx 30 minutes. I believe over the years the pipe has become partially blocked with leaves and silt. I have a set of rods but am unable to get the rods in due to the depth.
Can someone suggest an alternative tool that would allow me to 'pull' the debris out? Or would it be best to get a contractor in?
Many Thanks in advance
