outside drain problem
11 Nov 2008
my outside drain is blocked.....water is receading slowly,ive proded in the drain(blocks of grease i think have floated up) but it still seems very slow.....im thinking of getting some drain rods,see if i can get it to move,is there any stuff i can pour down get rid of grease build up or should i buy these or these wrong ones?....http://www.ebay.co.uk/itm/7-4m-LONG-DRAIN-ROD-KIT-WITH-100mm-rubber-plunger-and-50mm-double-worm-screw-/130747934336?pt=UK_DIY_Materials_Plumbing_MJ&hash=item1e712f2680
P.s kitchen outside drain.....1930's semi.......
its the gully.........ive no manhole in my yard,last year it got blocked ,i had home emergency cover and they used the rods and it was ok again.
got no home emergency cover yet.
