I am about to replace 2 * 500W flood lights. However, I struggled to find 500W so am stuck with 400W! On opening the box, the instructions request wiring in 1mm cable as opposed 2.5mm, which currently exists. I really do not wish to strip out the 2.5mm and replace with 1mm. E floodlights are under the eaves and I reckon I could force the 2.5mm through the grommet. If that is not possible then my only option is to either replace all the wiring back to the fuseboard in garage or leave the 2.5mm in upto a local JB and then wire from there to the lights in 1mm. Thoughts on the best way to proceed anyone?
Did not really fancy having different size cables and as I am at home I do not have a copy of the regs to hand.
