My garage roof is asbestos.The condensation inside the garage roof is unbeleavable.Has anyone had or have this.
I was informed the only way out is to have the roof removed?
I concur with foxhole, condensation forms when moist air hits a cold surface. It would be possible to upgrade the roof but that would be questionable compaired to remove and replace.
I have had a price for the removel of the asbestos roof.
Then will get the builder to put a pitch tiled roof
Hope this will cure the condensation problom
It'll certainly help as asbestos sheets can saturate anyway.....but you'll still need to ventilate, and prevent the moisture getting in in the first place, if you can.
John
