Hi there, I would be really grateful for some advice please. I currently have a very old, very rusted, high wattage halogen floodlight on the rear of my house. It does not have a PIR and is switched from inside the house (as one of a 3-gang switch that also controls normal kitchen lighting). I want to change the outside halogen to a PIR LED fitting. I have seen a lot of information about switched live feeds and permanent live feeds because that is what the PIR actually needs to keep detecting but suspect I don't need to worry about switched live feed, because the switch is in the house (which will just be left turned 'on' for my new light).
Am I right in saying that my old light won't have a switched live to worry about because the switch is inside the house? Once I isolate the old light back at the circuit breakers, my intention was to unwire the current light and use a waterproof junction box to connect the wires coming from the house to the wires of my new light. Does that sound right? Somewhat oddly, my new light has come with a 3pin plug attached, which I will cut off, so assume I just have 3 cables in the wire - usual L, N & E? Am I likely to just have those three cables coming to my old light? I realise all this may be easier once I chop everything off but wanted to get a headstart on thoughts?
Thanks.
Thanks.
