I have removed an old outside light and the cable ran down inside the cavity from the loft (bungalow) the out through the external wall to the light. There is a box it branches from in the loft.
The question I have is:-
Where should I run the cable, as I understand that cables should not be put in cavity for various reasons. So how do I route the cable so it does not look ugly? Conduit will look tacky - Cavity not suitable from everything I've read - It should not go horizontally through both walls (ext to int) and then to loft (otherwise you don't know the cables is there hidden in wall) etc.
So suggestion or pictures on how to make the job look good, but within all the guidelines that are now required.
