Hi
Firstly thank you for reading my post
I'm in the process of installing outside lights. I'm opting for a Blagdon kit to safely install electricity outside as I'm a novice.
I have a set of 4 lights. I want to wire them up in pairs (that's how I want them to be installed, so they work independantly from eachother).
I will connect the armoured cable from the power source to light number 1 but what type of terminal would I use or is available so I can then loop the armoured cable onto light number 2 - as inside the pillar style light I have purchased is a weatherproof box allowing me to connect the power cable...but there is no further outlet to loop the connection to the next light. I hope I am explaining myself well enough.
Can anyone make a recommendation...also note that if realtively small enough a terminal / junction box can be housed up inside the pillar lights as they are a foot high, square and hollow.
I would then repeat this process for the other two lights in the same way running which will run from a seperate cable.
I have seen many waterproof junction boxes which are literally just shells with no terminals... how would I connect all the wires....
Thanks in advance for your assistance. )
