Yes. Use uv proof cable or conduit. Also this comes under notifiable work. Meaning you need to inform your local council before you start work and pay them to do the inspection afterwards.
If the lights fit to the walls and practically no cable is 'outside' and you run your cable internally (inside eves, soffit, skirting, under floor) then it would be a minor addition to an existing circuit.
Thus no need to notify.
Set up would be:-
Existing light / light switch then run a cable between the existing light and the 1st new one, then from the 1st new one to the 2nd new one.
You should also audit the circuit use by adding up the total consumption in watts of all lights. Then add in the old and new external lights and make sure the whole lot are under the fuse rating on the board.
