I'm looking to install a Monarch Master HE ( or the Midi He, not decided yet). I have 20mm mains pipe coming into the house, then the mains valve is 20mm->15mm converting, then I have 15mm all the way inside the house. I have couple of questions before I can get the materials for the job,
1. Outside mains valve
I find the below right in front of my driveway, I assume this is my outside mains valve and the red one is the mains valve? I can't seem to move it by hands is there a special tool for it?
View media item 104121View media item 104118
2. If I can manage to switch off the outside mains valve, I 'd like to change the inside mains valve to leveller ball valve. I measured the pipe and it's 20mm, should it not be 22mm as all the valves on screwfix are 22/15/28mm?
View media item 104119View media item 104120
3. If inside mains valve is changes to 22mm one, is it worth to have 22mm pipe feeding the water softener then convert to 15mm to feed the inside of the house? I don't know whether doing this way I can have minimum drop of water pressure and flow? or should I just convert to 15mm from the mains valve and feed the water softener? I can order the softener with 15mm or 22mm bypass valve and fitting kit.
Thanks a lot for any advices.
