Outside socket
19 Aug 2010
Luton
Hi All,
I have an outside socket (non RCD) which is showing signs of age (the cover keeps falling off due to sun damage). I was thinking to replace it with a (32mA trip) RCD type but I find the outside socket is on the kitchen ring which is protected by a 32mA RCD trip at the consumer unit.
Do I need to / should I use a dedicated RCD outside socket?
Thanks, Chris.
If it already has an RCD there's no point having two. Have you got a means of testing the Trip times though? Is the mechanical part operating OK?
It's not necessary for the regulations, but...
... an active RCD socket - which also trips when the power is cut so not letting a plugged in tool unexpectedly spring back to life when the power is restored - might be advisable.
Also, some (maybe all) actually will not work if the earth wire is not connected.
Personally I wouldn’t want an rcd outside if not required.
It’s just more to get wet and go wrong.
No. But I put my voltage tester across live and earth and it trips.
Maybe it's best to use a dedicated RCD socket then.
https://www.tlc-direct.co.uk/Products/BGWP22RCD.html
How about this one?
Chris
As power tools can be plugged in anywhere in the house would you therefore advise every socket was an active RCD type?
If a newer thing offers greater protection, do you advocate it should not be used until all the others have been replaced?
