Hello all,
I'm having trouble replacing an outside tap. I'm fitting the new tap to an old female threaded wall fitting but, when I screw the tap in to full tightness, it points way off the vertical.
I've used fibre washers to space the tap away from the fitting a little so, at full tightness, it sits vertically. I put some LS-X on the female thread first.
I'm worried this isn't going to hold for long and, when pulling on an attached hose, the tap is also likely to get moved anti-clockwise and lose tightness.
I don't want to mess with the existing female wall fitting as the supply pipe is cemented into place close to the wall.
Any other ideas how I can get this tap screwed in so it's firm, water-tight and still sits in the correct vertical position please?
Thanks.
Thanks.
