If installing an outside tap with a hose union backplate so no exposed pipework would you still fit a drain off inside? Do many fit drain offs inside as most customers wouldn't be able to open them to drain it down. Thanks.
Interior drain off is to stop water freezing in outside tap , plus stopping water in outside tap being contaminated . outside tap should also have a double check valve .
If the supply rises up inside before heading out the wall then ideally you would have a drain at the lowest point. If it doesn't then opening the tap would drain the pipework.
There is a requirement to drain the pipework to stop any water becoming stagnant/bacteria ridden over the winter when isolated.
